#11 |
Liked 348 Times in 152 Posts
If you look at anything Speedmaster sells, the part number starts with "PCE" - ie: Pro Comp Electronics JUNK, is now, and always has been.
Phil Molski PMR Performance S/C 1623 |
#12 |
Liked 7,978 Times in 1,525 Posts
#13 |
Liked 650 Times in 194 Posts
You get what you pay for!
OTE=MR DERBY CITY;696114]Unfortunately Phil, there are always consumers out there looking for that DEAL …….[/QUOTE] |
#14 |
Liked 72 Times in 15 Posts
I think Broader only charges like $30-40 more then the socalled cheap knock off.
https://broaderperformance.com/produ...ke-valve-body/ |
#17 |
If you go and look at Speedmaster and see just how much stuff they "produce" your head will spin - not one single thing is of their own design - they even sell a belt drive for a BBF - if you see it in person, you'll never use it.
#18 |
#19 |
Liked 223 Times in 73 Posts
I have bought parts directly from Broader performance including his reverse valvebody kits he previosly sold and the one in the video, also his low gear set never had a problem with any of them or the price he charges. I have bought some tranny parts from speedmaster that broader doesnt have. I bought a C4 pump which are gettig hard to find good cores now days. the first one i got was missing the gear in it ha dto sen it back, i tried to get them to send me just the gears but they wouldnt. Got the next pump took it apart to inspect this one had gears. The casting case perosity was so bad that the presure side and suction side were one, would have never worked. there was so much aluminum casting that was breaking off that it did work it would not be very long. There is no customer support there just give you the run around evertime you called if someone answered the phone. the other part I bought was just as bad would not fit, couldnt even assemble it.
Any body got a good source for C4 pumps
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
