Old 10-08-2024, 03:32 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Rear gear question
As I stated in post #5
Originally Posted by 1320racer View Post
For optimum ET, If it was mine, it would have a converter that flashes to 5800, I?d be shifting at 7200 and gear it so it?s crossing the stripe at 7700. I would also get a 30? tire under it if you can not go wider.
Old 10-08-2024, 05:13 PM   #2
L.Fite
Liked 497 Times in 243 Posts
So...
Stupid me is going to throw this out there...
Peak torque is at 5300...
It makes plenty good torque for a 3.75" stroke...
If it falls to 6200 at the gear change I'm going to say you're leaving some power on the table...
I would think if you send dyno sheets to someone like Coan, they could dial you in...
May find you can tighten it a bit?
I think maybe play with the shift point...
As in higher... 7200? maybe more...
See where it slows down...
More gear would help, as would a 3 speed...
If it crosses 72+ it really doesn't matter if the motor doesn't self disassemble...
(don't know the parts or build)
I see things I might try if it were mine...
Depends on your budget really, converters/transmissions aren't cheap these days...
Any way just a few thoughts from a dumb ol' Texas boy...
Maybe some of this helps...
Maybe it don't...
As they say... "Your mileage may vary"
L.Fite is offline   Reply With Quote
Old 10-08-2024, 06:14 PM   #3
Bob F
Liked 16 Times in 11 Posts
Its a 440” LS with 4.125 stroke
Bob F is offline   Reply With Quote
Old 10-08-2024, 06:55 PM   #4
L.Fite
Originally Posted by Bob F View Post
Its a 440? LS with 4.125 stroke
Sorry... Thinking Chrysler...
So...Yeah, Think I'd experiment with shift point, doesn't cost anything, just time...
Still think more gear...
Converter...
There's stuff to try before springing for a trans...
Haven't tinkered with LS stuff...
Old 10-08-2024, 07:09 PM   #5
1320racer
1320racer's Avatar
There?s no question, more gear, higher shift, maybe a converter but not before real data via a data logged but not a 3 speed trans.
Old 10-09-2024, 10:11 AM   #6
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Stan
Old 10-09-2024, 10:42 AM   #7
1320racer
1320racer's Avatar
Stan, what part of the TRUTH and the FACTS don't you like?
