Old 12-03-2008, 11:13 PM   #3
OWNSS
Default Re: 82-92 F-body stock rear sway bar
If you have no restrictions on what you can run go with the Spohn 1" drag bar. If you can only run stock parts then looking into the 87-92 GTA Trans Am rear sway bar or the 88-92 1LE Z28/Trans Am sway bar. They are the 2 largest GM offered on the cars from the factory. The GTA bar is much easier to find compaired to the 1LE.
1999 Camaro SS
11.14@124 1.57 60ft
OWNSS is offline   Reply With Quote
