We have a set of Mark's (Performance Welding) collectors for the Hooker headers we have. I do think they work, it seems to show some on the dyno, and maybe more so on the track. I'm sure they'd do even better if the headers were better matched to the engine.
Alan Roehrich 212A G/S |
Liked 282 Times in 103 Posts
With all of the references to Mark at Performance Welding,does anybody know if they are still paying contingency for 2009,or did they drop out too?Last weekend,I removed ALL decals from my car and I am starting from scratch.
Liked 186 Times in 55 Posts
Put a set of performance merge collectors on my headers that Pete Z made. on the dyno gained horspower and torque compared to the stock collectors.
Bob Lasko 1134 SS/CS |
I had some custom made headers with the supposedly appropriate merge collector installed. Car was lazy off the line. Next weekend I had a merge collector with a substantially smaller neck. Launced like a rocket. In fact, it suddenly had a fuel starvation problem I never had befor on launch. Luckily I had a new needle / seat I wanted to try in the tool box. Installed it and the car was .20 quicker than ever.
Past performance is not an indication of future performance. Individual results may vary.
Jeff Lee 7494 D/S '70 AMX |
Liked 5 Times in 3 Posts
I'll report back later...on the car right now is a set of Hookers (they have a hooker tag?) with a 4 into 2 into 1 collector. I just put togather a set of Hedman's with a merg collector...so we'll see.
Liked 4 Times in 2 Posts
Just call Mark @ Peformance Welding, his work is very good! just put a set of new headers and collectors on my 70 Challenger, they fit perfect. have them on my other cars as well, GOOD STUFF............... Mark is a stand up guy. he will work with you. to sort out any problems.
Liked 6 Times in 3 Posts
question to Bob Lasko - what is your enigine ci/ rated horsepower and what was the difference in hp and tq that you saw after the change.
and thanks to all others that have been answering my question Ian |
i just ordered a set from performance welding, i'll report when i get them. Mark asked me every detail of the cam card, horse power info, mph info and then told he had to put the collector together based on the info. it is nice to know that as i am running an ihra crate motor class (not very common), and he has to put something together for the combo and not just go to the shelf and pick one that is close.
Ian |
First of, i'd just like to say i got a set of mark's performance welding stainless merg collectors recently and the workmanship was excellent. Also he was the only one out of three places i contacted that required my full cam specs - et and mph to put a set together for me, the other two said " they had something in stock that would work". Thank you for that Mark.
Secondly i have to add that i purchased a set of Schoenfeld stepped headers right out of their catologe and during testing (dyno) on a IHRA D/CM fast burn motor these headers out performed two different custom made headers by 17 and 11 horsepower. I order a second set of the same headers without the collectors and added the pref. welding merg's. We dyno'd my engine (ihra crate 350ci/340hp) yesterday and after tuning with the schoenfeld headers/ collector combo it made 455hp with over 400 ft/lbs carried from 3973rpm to 5554rpm. We changed to the schoenfeld/ perf. welding collector combo and after tuning added 2 jets sizes to the rear, took one degree off the timing and hit 474 horse carrying over 400 ft/ lbs from 4113rpm to 5944rpm and this was all on sunoco 94 octane pump gas. changing to 104 race fuel made gains to 478 horse and carried the 400 lbs to 6300 rpm without any jet changes. oh ya, it maxed out at 444ft/lbs on 94oct and 455ft/lbs on the good fuel. so i'll take this time to thank Schoenfeld Headers, Performance Welding and Fiorravanti Custom Engine for all your help, and you guys for answering my questions. Thanks Ian |
That's awesome Ian, you gotta love it when it works out like that. Mark's collectors do work and here is proof! Good luck this year! Shawn
Shawn Blair 6383 SS 634 STK |
