Old 05-26-2009, 02:31 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: PCV, advantage or not?
I have run them both ways and as mentioned above, they are closed at wide open so no difference in performance. However, I think you will see less valve cover "milk" with a PCV. [maybe]
Usually I do not run a PCV but see no problem with doing so.
Larry Woodfin 471W
Old 05-26-2009, 05:54 PM   #2
Chris1529
Liked 70 Times in 29 Posts
I have a pcv valve on mine.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-26-2009, 07:45 PM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i run two,and the engine is sealed good ,no dip stick or breathers,havent had a data to say weather if theres a horse power gain gmonde
Old 05-26-2009, 08:46 PM   #4
Bill Harris
Liked 26 Times in 13 Posts
I know of someone who tried the two PCV deal, no breathers, etc on an engine on the dyno and lost serious power. The idea is that the PCV valves would make a poor-man's pan-evac, pulling a vacuum on the crankcase. Problem is that like it has been stated, PCV valve(s) is closed at WOT so the idea falls apart. Pressure builds in the crankcase and you lose power.
I have run with and without a single PCV with a breather on the opposite cover back to back. It made no difference except that I get less oil blowing out the dipstick tube when there are two open breathers than when there is one with the PCV. The pressure has to go somewhere, and no matter how well sealed the motor is, there is going to be blow-by.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 05-26-2009, 09:50 PM   #5
Bub Whitaker
Poor-mans pan evac, exactley! If you lost serious power on the dyno, and your blowing oil out the dipstick tube, then you need to work on your ring seal. Serious blowby unloads the top ring and blows oil out the dipstick, causing loss of power. This is one way you guys can check to see if your rings are sealing. A good ring seal will pick up with the "poor mans pan evac"
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 05-27-2009, 01:38 AM   #6
Jeff Lee
Jeff Lee's Avatar
Bub's right and you wouldn't believe what I have spent on the dyno with PCV's. The good news is they work. But there's a lot of buts and I'm not going to tell all because my engine builder would kill me!. But I will share that not all PCV's are created equal! That's why there are so many part numbers. I bought from the discount stores and the OEM's. I looked at late model (emphasizing the low drag piston ring models) equipped on small blocks to big blocks to the older stuff. There are more effective ways to find HP, this is just one way to get there.
Jeff Lee 7494 D/S '70 AMX
Old 05-27-2009, 09:24 PM   #7
junior barns
Liked 20 Times in 14 Posts
what does PCV stand for?
junior barns is offline   Reply With Quote
