Old 05-28-2009, 09:18 PM   #1
Jesse Knapp
Default Turbo 350 vs. Metric 200 (stock eliminator)
Which one is faster behind a smallblock combo? Heard the stories that the 350 can be as fast if it's high dollar stuff. I also heard the 350 is more durable. I've raced 350's and glides but never a 200. So, if one does a Rossler or another high end piece, will the 200 go faster (quicker)? My concern is not as much about durability. I care more about elapsed time. Are there any problems with a 200 fitting a (68 to 72) Nova? The stick idea is very appealing to me, but my lack of knowledge in the clutch area makes me lean towards the automatic again. Thanks for any replies.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
Old 05-28-2009, 09:29 PM   #2
Liked 1,932 Times in 435 Posts
Default Re: Turbo 350 vs. Metric 200 (stock eliminator)
The 200 fits where the 350 fits, same drive shaft, mount, and cross member, the 200 is actually smaller. Most say the 200 is faster in a small block car. If I were going to a 200, I'd get a McClay, and I'd get the pump modified so a regular turbo converter fit.
Old 05-28-2009, 09:32 PM   #3
junior barns
Liked 20 Times in 14 Posts
I remember Keith Lynch saying the 200 was quicker than his 350 both quality pieces (so he said)!
I think Rossler does the 200 also. He should be able to give you a good idea
Wish I had the xtra money to buy a good 200 to find out for myself
junior barns is offline   Reply With Quote
Old 05-28-2009, 09:36 PM   #4
Jesse Knapp
Thanks Alan. If it's a bit smaller, then is it lighter as well? Also, with the deep aluminum pan, is the oil capacity the same as the 350?
Old 05-28-2009, 09:55 PM   #5
Liked 5,153 Times in 1,967 Posts
Yes ,it is a bit lighter to start.
There are two different factory fans. The deep one holds about one more qt.
Leo (Remac) sells a fabricated aluminum pan.
Old 05-28-2009, 10:02 PM   #6
Yes, a 200 is slightly lighter than a 350, even if the 350 has both aluminum drums, and the 250C shell and gear train.
Given the same depth pan, a 200 holds less fluid than a 350.
Old 05-28-2009, 10:05 PM   #7
Bill Edgeworth
McClay is the only way to go.
I think Scott told me its 26 pounds lighter than a 350. The pump conversion is a good idea I had him do it to my 200. Also the auto 1-2 is a good option to get for consistency. It’s real easy to adjust and it’s an external adjustment. The case brace and needle bearing output shaft are also a good idea. My McClay is considerably faster than my 350 with about the same low gear.
I put over 400 runs in a 3600# car on it before sending it back for freshening and he said it was in great shape. So properly built they are quite durable.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 05-28-2009, 10:16 PM   #8
Bill Edgeworth
One more thing I should add and maybe someone like Mark Yacavone who knows vastly more than I ever will about 200’s could comment on this:
You need to let your converter builder know it’s going in front of a 200 with a 350 pump conversion.
Something to do with direction of oil flow and excessive pressure build up in the converter. I heard this from Coan.
Old 05-28-2009, 10:57 PM   #9
Thanks Bill, It most likely has to do with using the support bushing ,either inside the pilot, or in the stator support. I don't build 350 conversion transmissions. I just build straight 200 converters to go with my trans's.
My new 305 converter will be for straight 200s, at first,which I think will be the most popular.
Again, Leo also builds the 350 conversions ,as does Jack Sepanik and a few others.
Old 05-28-2009, 11:21 PM   #10
Alan Warman
Mark
Thanks for all the info and help last weekend.I found the valve body was the problem.Talked to Billy Lynn and he told me what to do.Did not get to go to Dallas.But will be ready for PineValley
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
