Old 06-15-2009, 08:39 PM   #20
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: 5.0 stocker rear control arm bushings
If they are moving that much, WOW!!! If the holes are enlarged. The quick fix is to weld a washer of the same diameter as the hole that you have through the control arm. You just need to make sure everything is square first. Something is very wrong.
Sean
Sean Marconette
84 Mustang
5060 SS/N
