Old 06-23-2009, 10:12 AM   #6
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Trailer wheel bearing question?
You should only use the bearing buddies on axles that are meant to use them, They have a small hole drilled in the axle shaft to let the excess grease escape. If you dont have that relief hole you can push the seal out of the drum and then you have a mess and alot of dirt in your bearings.
