Liked 544 Times in 213 Posts
The LS-6 454 SS engine combination has used the open chamber heads at the closed chamber CC for years and years. I machined a number of sets so I know how they got from 119 cc's down to the legal CC number.....
I just had a friend ask me about doing an engine using the 401 heads and wondered the same thing...How did these heads become acceptable for an engine that used CC heads. I am assuming the arguement that the legal iron CC heads are getting harder to find and more expensive is how these aluminum heads came into the picture...... '840's and '291's There are also aluminum CC stock GM versions..... A friend has a set....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 07-23-2009 at 07:35 PM. |
Liked 13 Times in 7 Posts
Ed and Rich,
So you guys are saying that they modify or aluminum fill the 118 CC open chamber 401 head to get it down to the 103 or 104 CC closed chamber spec in both Stock and in Superstock? sorry for my ignorance
N/A |
Liked 18 Times in 4 Posts
I have run the 1971 425 HP LS6 with the 401 alloy heads for several years. You can angle mill the heads to get the chambers down to 104 cc's. Same thing on the Iron heads. You have to cut .100 off the plug side and 0 on the manifold side, then correct the intake manifold face.
Bryan Broaddus 7568 STK ,SS |
I didn't want to be the first one to say how I made them the right CC's......I angle milled the iron open chamber "990 heads......zero to .125" than flat milled them the rest of the way. corrected the intake side and faced the head bolt bosses to make them for an LS-6....I did not realize the 401 heads were being used for that engine as well.....
Banned
when you angle mill a head you change the valve-angle..another of those "grey areas" i guess..while many makes doesn't get a replacement head at all..some others can just "make heads fit"...
