Old 08-12-2009, 03:09 PM   #19
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: Who Sells the Adjustable Brake Pressure Launch Control Switches??
The adjustable pressure switch cannot and will not add delay.
This is because it is controlled by the brake pedal. If you set the switch-on pressure very low, the engine will be late coming off the two-step, but the car will have already started rolling, because you have released the brakes. So, it rolls out of the beam at 2300 rpm, or at whatever rpm the two-step is set.
This is why the old brake light switches from early Fords, for example, don't work very well. They are very sensitive to brake pressure, and the switch closes at something around 100 lbs.
On the other hand, a switch that closes at 800 lbs can be very uncomfortable to hold for any length of time. And maybe 500 lbs is comfortable for you, but not enough to hold the car at your chosen rpm.
The object is to get a quick release of the switch, before the wheels start rolling.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
