Liked 239 Times in 114 Posts
Pontiac also had a filter adapter that rotates the filter back at a 45 deg angle . Available from some of the Pontiac restoration sites. Used on Gen 1 Ram Air Firebirds, and 428 HO in 67-69 B-bodies. Then you can run a full size filter.
Been there done that. First of all he will need the angled oil filter adapter if he does not have one. Then purchase a NAPA Gold 1522. This filter will be a little smaller in diameter and shorter.
BTW...the angled oil filter adapter will point the filter towards the engine. |
Liked 5,121 Times in 1,952 Posts
AC, PF 61 is the small dia, full length filter. .....307 Olds
It's usually not the length that's the problem. It's the diameter, and getting it in and out of it's location.
Liked 56 Times in 27 Posts
FED 387,
Just what Mark & ss3011 said on the adapter... You can also use a walmart filter #3675 small dia/ full length... There is a small dia/ skort length but I didn't have number.. Filters work great and also fit my 5.7 + 6.0 GM Suburban....
Dave Ribeiro 1033 STK Last edited by Dave Ribeiro; 08-14-2009 at 05:26 PM. |
