Liked 16 Times in 11 Posts
Yes for real, Greg runs his and there are a few other 63 alum cars that run and a few in garages like Jerry Stein's
Bob Pagano A/SA |
Bob, the number you posted is three hundred-twenty thousand. Did you mean $32,000 by any chance?
Oops, yea 32000. but the car was real ruff, a good comparison would be Dan Dvorak's 63 Dodge Alum car for sale at 79000. and is perfect.
Bob Pagano A/SA |
Liked 10 Times in 10 Posts
I thought you guys were talking about D-Darts.The only difference between a 273 Hi-Po (235 HP) and the 273/275 HP (D-Dart)was the camshaft (Cam-Craft .495/.505 lift / 284 duration), and Racer Brown 250 lb. ratedvalve springs.The carburetor was a Holley 600 cfm-rated, vacuum secondary unit, as opposed to theCarter 500-cfm AFB unit on the 235 HP rated engine. To allow for the Holley carb butterflies to open, the stock cast iron intake wasmodified (a free-breathing flow intake as Chrysler put it), the throat openings were bored out an additional 3/16".It really doesn't sound like a 40 HP improvement over the 273/235 HP Commando.I think the NHRA currently rates the 273/235 HP at (220 HP). As someone posted earlier, the D-Dart engine should be re-rated.Not that it would matter, because who in the hell would try to run this car in stock class, and be competitive. Not at 275 HP.Paul (Former 273/235 HP racer)
Liked 63 Times in 7 Posts
You guys forgot, Rod Kisters, famous 1960 Pontiac stocker, "BIG IRON", out of Scotts Bluff Nebraska. It was a daul four barrel 421 " 4 speed car.
Eddie Rezac |
Banned
Liked 235 Times in 110 Posts
I believe Rods 1960 Pontiac was a 389 SD with 3 X 2's like Dick Hills 1960 Pontiac out of Penn. The 421 SD with 2 X 4's didnt come out until late 1961 and was run at the 1961 Nationals as O/SS. Anyone have some different info?
D-Dart (D/Stock) Info from 1966.
D/S Class/Factor 10.60 - 11.29 D/S NHRA record...12.98 (February 1966) D-Dart ran in C/Stock in 1967 (Classes bumped up one, by NHRA) D-Dart ran in F/Stock in 1968 D-Dart ran in G/Stock in 1969 thru 1971 HP rating never re-factored. NHRA did not have any records of listed competitors in registry for 66' 273/275hp Darts. For G/Stock or SuperStock/J. Successful D-Dart racers, Ted Spehar "Spehars Automotive" 66' - 67' and Bob Banning "Little Ramchargers" w/Dave Reitz driving, 66' - 67'. Both hit 12.90's in early-mid 67'. Time to re-factor. |
#8 | |
I agree except the Holley was a 4160, list 3778 rated at 750 cfm. This is the carb off the 65 race hemi.. Also, didn't the motors have a spacer for the butterflies to clear? |
W J,
Yes this is rally a D-Dart thread. But since you brought the 273 Commando's up. Yes they could wind. Didn't want to bring this up on this thread. But back in May 1968, my father bought my mother a 67' Barracuda Fastback, yes with the 273 Commando, 4-speed with the console. Yellow, with black interior. It was equipped with the Performance Group. HD rear-suspension, HD torsion bars, Front Sway-bar. Sure-Grip 3.23 Posi. 6.95" x 14" white walls with deluxe wheel covers. Yes with that special singl-exhaust with the chrome-tipped resonator. No, it was not a Formula-S. Cost, $2735, from McNulty Chrysler-Plymouth, Carmel, New York Only 4000 miles on it. The sales managers wife didn't like the 4-speed. Either did my mother, it was a horrible long-throw Inland shifter, with the reverse trigger (equipped with a rubber-band tension thread). A real pain, when utilized with the console. Paul |
W J,
June 1968, my father takes my mothers car to Dover Drag Strip, classed in J/Stock. Without her knowledge, of course ![]() With the air cleaner on (Chrome unit, w/Commando lettering), spare tire in trunk and no air adjustment for the tires, ran an honest 16.35. First time out won class trophy. Beat out a couple of 66' 289/225Hp Mustangs, a 68' 290/220HP Javelin and a 65' Chevelle Malibu convertible 327/250 HP. Thats all it took. Paul |
