All the older engines (50's,60',s,70's) need to have a legal replacement option. Some of you are looking for 40 year old heads today, that will be 50 year old heads 10 years from now! The integrity of super stock (and stock) is long gone. They are legal, but I don't think .937 keyway lifters and sheet intakes are in the spirit of the class, but it is what it is. A super stock motor is nothing less than a comp elim. motor with less compression, and legal part numbers on the heads and carb(s). Fords and Chevys already have the option, the wedge mopars need the same.
Liked 328 Times in 80 Posts
I say if you want Aluminum heads find a combination that uses them and go with it. If your brand doesn't provide such a thing, you know your options. Don't press the issue, for all other racers to have to invest in new heads and associated work, to appease your own interests.
Oh, I do have an aluminum head combination. Watch those valve seats! Ernie Neal SS3400 |
Liked 19 Times in 7 Posts
There are plenty of late model engine combos available to run in Super Stock. If you can't find the heads you need at an affordable price, try running something that you can find heads for. If aluminum heads are made legal across for all Super Stocks, then everyone has obsolete heads and the market dries up to sell the heads that everyone has alot of time and money into. It just makes Super Stock racing that much more expensive. The AHFS can't adjust the horsepower factors now, let alone if you add more Aluminum heads to the game. Keep things the way they are.
ss/gt 93 t-bird |
Keep things the way they are?
I'm wondering if the SS/GT class was created (in part) because the 40 year old bodies were getting hard / expensive to come by? Take the same gripes about aluminum heads and apply it to the GT classes. Seems like the issues are nearly identical.
Jeff Lee 7494 D/S '70 AMX |
#5 | |
ss/gt 93 t-bird |
#6 | |
What I'm trying to say is the same gripes that were heard from racers of "traditional" SS racers (same make / model / year engine in like chassis) would be the same arguments against non-oem aluminum heads being used today. I'd like to spend more time here but have work to do. So follow along with my poor logic and lousy comparisons.... GT gets a more aerodynamic car - SS has to deal w/ cast iron issues GT gets a newer car that's easy to find - SS gets a head thats hard and expensive to find GT gets a car that doesn't have 100,000 miles on it - SS gets a metal fatigued car GT says build one; your allowed - SS says, "I've had this car 20 years & not changing" Hopefully you can see my point that these things just keep happening with NHRA, everybody has their point of view, they all hunker down together and in the end life goes on. I'm for aluminium heads (about $1500 from Edelbrock for my AMC) because I don't think one group deserves an advantage over another. Will I rush out and buy a set tomorrow if approved? No, can't afford it right now. But if / when my cast iron heads start leaking all over I sure will appreciate that option. And nobody has mentioned thermal efficiency. Maybe the guy with a 8.5:1 compression engine won't benefit from aluminum heads? So let him run his choice.
#7 | |
For all of you that want to cry about the expense; I can tell you from experience. I have one of each, and aluminum head motor and a steel head motor so I know the cost for a fact. First the aluminum heads cost me more to purchase, but they where new not 40 years old, second they didn't have to be checked for cracks, sent out to be welded. Bottom line is that the aluminum head motor actually cost a couple thousand dollars less to build; best part is that I don't have to drain my motor at the end of the day. So; the expense part is crap! I don't care if the replacement heads are steel or aluminum, but it would be easier for the replacement heads to be made of the same material for sake of HP and weight that needs to be added. I said aluminum, because most of the replacement heads allowed now are aluminum; so why not stay constant. Finally some type of replacement has to happen in order for traditional classes, not GT remain alive and well.
#9 | |
ss/gt 93 t-bird Last edited by dwydendorf; 10-23-2009 at 11:40 AM. |
#10 | |
Liked 163 Times in 53 Posts
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
