Old 12-14-2009, 09:46 AM   #10
Darrin Christen
Darrin Christen's Avatar
Default Re: PG gear ratio?
I ran a 355" sbc in a 2860# chevy II with a 1.76 glide 5.67 rear gear. Car went a best of 1.33 60' @ 9.86 and consistent 9.90's @132mph at 8200 rpm in cool weather. I put a 2.03 low gear and 5.43 rear gear. 60' times dropped to 1.30-1.29 and ran basically the same E.T. and mph at 7900 rpm. You will have more rpm drop at gear change with the lower gear ratio. Car has a 8" 5800 convertor and a 15" x 33" 105" roll out. I leave with the trans brake at 4200 rpm. The car was more consistent with the 2.03 low gear due to being able to transfer the weight better, and a whole lot more fun to drive! The 2.03 broke after about 350 runs. I put the good old reliable 1.76 back in for now! Hope this helps.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
