Liked 2,486 Times in 697 Posts
Jim : I run .113 and .095 Jets on Stocker. .045 on bottom step is OK. The 1968 up cars ran a 3 step metering rod with cupped retainer while 1967 back had 2 step and flat top.....also as I recall a shorter primary jet. If you mix combo up it will run like cr*p. If you are in Vegas, I would be happy to take a peek at your carb or loan you one if you guys promise not to put that male s*x doll in my Demon again. John Irving
