#15 |
Liked 520 Times in 132 Posts
Update the front mounting holes for the ladder bars are eggshaped also.
Upon cleaning and further inspection I found the following on the left axle tube. The weld at the center section appears to be cracked. On a Dana 60 the top of the axles tube where the axle bolts up is fairly flat. When you have the drivers side axle tube level the left side(the one that is cracked) is twisted about 3/8 of an inch. The pic with the ladder bars shows how different they were adjusted in the car. Taking the rear to chassis shop monday to get repaired. Will sleeve the ladder bar mounting holes and hopefully make Pine Valley. On a good note I took some measurments and everything is square in the car. Ed ![]() ![]()
