Old 04-07-2010, 01:05 AM   #1
SS Engine Guy
Default Re: DP #24 Engine failure....
http://www.akerlychilds.com/
Clevite series bearings.
http://www.kingbearings.com/advantages.html
A very good alternative and on the fast side.
There is alot of black majic in bearings.
One thing to note: On ALL rod bolts keep a log of free standing length. When new go to full stretch (not torque) in specs 3 times. (Usually 2 of these are during the resizing process.) If free standing length changes over .001 at any time crush threads with a hammer and discard ALL of the bolts. You are very likely already doing this. If not you will be astonished at your findings in batch to batch metalurgy/strength/Rockwell ratings.
SS Engine Guy is offline   Reply With Quote
Old 04-07-2010, 05:48 AM   #2
LSP
Guest
Posts: n/a
Drooze, are both the 5.7 and 6.1's aluminum blocks?, if so, are there iron blocks available for each?
Old 04-07-2010, 06:05 AM   #3
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Is there anyone betting to see how long this thread will last? I got 5 bucks payable via paypal that there is 40 more posts and at lease another 20 of the those will be novel lenght replys.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 04-07-2010, 12:14 PM   #4
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
I got 50 that says it will last until at least Christmas and have over 40 more posts, all over 500 words wanna bet
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 04-07-2010, 08:25 AM   #5
Neither is alluminum block....both cast over the shelf same as street car.
5.7 has thicker walls can go .075 over usually no problem.
6.1 is thinner .030 max on a GOOD sonic check if youre lucky.
Our 5.7 is from an 06 Jeep Cherokee.....
Old 04-07-2010, 11:10 AM   #6
Ken Haase
Wink Re: DP #24 Engine failure....
Crate Camaro, no takers here. And I wouldn't expect any, either. I mean, after all the thread starts like this.....
"Ok, I feel compelled to post..." (said a mouthful there Droozie)
I probably should have used all caps on the 'compelled'.
Crate, you're estimates are likely too low. But I just helped get you started toward your goal.
Ken Haase is offline   Reply With Quote
