Just looked at the pictures from Boise. Great pictures including Les Norton's BEAUTIFUL Rod Shop inspired Salt City Dodge Challenger.
Liked 325 Times in 50 Posts
If I were you, I would ask about the adjustable attatching points for the rear suspension. I did and if I were you, I would also. Mine has one hole per point and is not adjustable. Other than that, they are the virtually the same. I know mine passes, and yours might be ok also.
Jeff Teuton 4022 STK Last edited by Jeff Teuton; 05-06-2010 at 10:32 AM. Reason: Spelling |
Liked 14 Times in 11 Posts
On what website are these pictures available for viewing?
Phil Saran Parker, Colorado |
Philip, here is one place to view Les Nortons Challenger.
http://www.dragzine.com/news/les-nor...ak-challenger/ The other thread on Class Racer seems to have disappeared! |
Another Drag Pak hits the track....
Very nice too! Lots of little touches... David The New Hemi Guy |
Liked 101 Times in 52 Posts
From the Dragzine..com site "The 2010 Drag Pak Challenger, much like the 2009 version, will be a factory-developed body-in-white vehicle kit based on the 2010 Dodge Challenger SRT8. The car will feature a 1,000 pound weight reduction with the removal of major components and systems, a lift off hood with a functional scoop, Dodge Viper-style front seats that accommodate 6-point harnesses, and polycarbonate door windows.
Other features include a modified transmission tunnel, raised floor for solid axle conversion, solid engine mounts, shortened wheelbase, special modified K-member, lightweight drag race only front brake assembly, and manual rack and pinion steering. Engine packages include the 5.7-liter, 6.1-liter Hemi and 5.9L Magnum. The standard 6.1 Hemi features a forged steel crankshaft, forged 12:1 pistons, a hydraulic roller cam, .584” valve lift with 1.6 ratio rocker arms, and a special high ram EFI intake manifold with a 4-barrel throttle body. Both a four-speed automatic and 6-speed manual transmission setup are part of the package, although the transmission itself is not. As stated on the order form, the car requires extensive work following delivery, as it lacks a roll cage, safety equipment, wheels and tires, transmission, and many other components that make it race-ready." I did not realize these didn't come as an assembled car, but rather what would be called a craftsman kit of some sort. It mentions "raised floor for solid axle conversion" in the text. When Corvettes change do they modify the body also? Is it still illegal to modify the wheel well to fit a 9" tire in a car then? Is the Mustang actually a running car when delivered? |
Banned
shortened wheelbase, raised floor SOUNDS LIKE A REAL FX CAR FOR SURE!!!!! QUOTE=Bobby DiDomenico;186196]From the Dragzine..com site "The 2010 Drag Pak Challenger, much like the 2009 version, will be a factory-developed body-in-white vehicle kit based on the 2010 Dodge Challenger SRT8. The car will feature a 1,000 pound weight reduction with the removal of major components and systems, a lift off hood with a functional scoop, Dodge Viper-style front seats that accommodate 6-point harnesses, and polycarbonate door windows. Other features include a modified transmission tunnel, raised floor for solid axle conversion, solid engine mounts, shortened wheelbase, special modified K-member, lightweight drag race only front brake assembly, and manual rack and pinion steering. Engine packages include the 5.7-liter, 6.1-liter Hemi and 5.9L Magnum. The standard 6.1 Hemi features a forged steel crankshaft, forged 12:1 pistons, a hydraulic roller cam, .584” valve lift with 1.6 ratio rocker arms, and a special high ram EFI intake manifold with a 4-barrel throttle body. Both a four-speed automatic and 6-speed manual transmission setup are part of the package, although the transmission itself is not. As stated on the order form, the car requires extensive work following delivery, as it lacks a roll cage, safety equipment, wheels and tires, transmission, and many other components that make it race-ready." I did not realize these didn't come as an assembled car, but rather what would be called a craftsman kit of some sort. It mentions "raised floor for solid axle conversion" in the text. When Corvettes change do they modify the body also? Is it still illegal to modify the wheel well to fit a 9" tire in a car then? Is the Mustang actually a running car when delivered?[/QUOTE] |
2010 DP Challengers have only the 6.1l engine package.
