Old 05-12-2010, 07:51 PM   #1
ericsz
Default Leaf spring perches are bowing
Ok for those of you that are using after market rear leaf perches have you ever had this problem? I have installed a 3* pinion shim in the car, raced it 3 times looked under it and now the perches are bowing in the middle keeping the base of the shim from being flush with the perch. Can you lead me in the right direction of getting some heavy duty perches??
Eric Bowling
ericsz is offline   Reply With Quote
