#1 | |
Edgar |
The bottom line on most of this stuff is you never really know! So if you want to go fast, you have to try, try, and try again! And yup, that sure can get expensive!
And since you are looking at racing a basically unchartered path with this combo, you will have considerable time and effort involved into making this a successful venture. That unfortunately sometimes, takes a fat wallet! Look at Mike Keener here, two transmissions taking up space. I think I'll PM Mike and see if I can steal one from him... ![]()
Jeff Lee 7494 D/S '70 AMX |
Liked 317 Times in 108 Posts
I was wondering on these 4 -5 speed comparisions about first gear ratios could ones that ran better w 4 speed had lower first in the 5 speed and not enough rpm to get enough wheel speed with lower first gear and that hurt there performance?
Mike Taylor 3601 |
Liked 22 Times in 22 Posts
I am just now getting ready to use 5 gears for the first time. will let everyone no. but if 4 gears were faster, prostock would be using them. Just my 2 cents.
don,t have one |
Liked 70 Times in 29 Posts
I think your advantage would come from having less drop between the gears.
First may not be all that much lower in a 5 speed, but the drop isn't as great to the next gear. I'll bet that most people's fifth gear is still 1:1.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
All high gear drag cars in class are 1 to 1.
don,t have one |
I think it is true that the engine's specific power band plays a part in the question of what improvement is seen with a 5 speed. However, I am pretty sure a 5 speed will need to be shifted differently than a 4 speed.
Here's what I'm thinking... We grossly over rev our Super Stock engines on the gear change. 4 speed guys are revving them about 700-1000 over peak HP, maybe more. My limited understanding is comp guys with 5 gears are running about 300 over peak HP before shifting. Please chime in if you disagree with my #'s. I am not an expert with comp engines. My belief is the more gears you have, the less you will need to run past peak horsepower to recover on the subsequent gear. Also, I wonder if the finish line over rev could/should be reduced with a 5 speed. Again, my limited understanding is that comp guys are running about 400-500 over peak HP instead of us Super Stock guys running 1300-2000 over. Just some thoughts... Last edited by Mike Dahl; 05-21-2010 at 01:23 PM. |
Liked 1,607 Times in 584 Posts
Any manual transmission, either 4-speed or 5-speed, needs proper gear ratio selection for optimum performance based on the power band of the engine. Engines with narrow power bands, benefit with 5-speeds.
The gear ratio selection needs to be optimized to allow the engine to recover and stay in its power band through all gears. In order to keep their engines in the power band, I have known of SS racers with small CID engines, that must run a 4-speed, put a 1.1 or 1.2 high gear on their 4-speeds. |
