#51 |
Liked 1,829 Times in 427 Posts
Well put Bernie
Drools dont you get it you give DRAG RACERS A BAD NAME. What happen now? Bomb builder made a mess again? Why did he get DQed? ...I m sure he fonud the scale .. ..Can u say the same...NO By the way much better talent avalible in Mass ,,Mandie aint all that.. Dont compare you POS to Erics or Roys..They are Racers ..U R NOT.. Drools Racin More Excuses than BP..... Cant stop the oil leaking..More $ than God,,So you imply... Withdraw by Monday 12;00 .... Dont Forget...
james perrone 1290 STK |
#52 |
I'm not sure why Carey Bales was DQ’ed at Chicago...Does anyone know why?
The "R" on the window from Chicago means the driver was going to try to set the Record for that particular class.
Alex Owens - STK - 3913 - Alkey Alex Photos & Stats http://alkeyalexphotos.weebly.com/ https://www.facebook.com/alkeyalexphotos |
#53 |
#54 | |
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
#55 |
Liked 77 Times in 15 Posts
Congrats to you, Mr. Merryfield. Sounds like you had a dream/great week with your new car.
#56 |
Liked 136 Times in 49 Posts
Originally Posted by hemidup dp# 53 Yes it indeed is drag pak #53. Mike Roth did the amazing buildout and plumbing, and sourced the wiring guru Rick, graphics,etc, etc, etc. It is truly a stunning race car. The engineering, and attention to detail and craftmanship are second to none(in my humble opinion) Rick Allison did the tranny Jeff Taylor went through the motor. Picked it up in Lebanon IN Wensday around 5PM. 1 1-2 shift on his street, quick do's and don't. Towed on open aluminum trailer straight to Bristol Thursday in time for sign in and tech. The cars maiden run down the track was the #1 qualifying run. She won class later in the day.... I learned a lot about this new race car, especially what not to do in eliminations! Will make some tweaks to it for my driving style. And yes it earned HP on Monday. The car is called the Minuteman Missile. Missile's go flat out, they don't lift. Eric __________________ Eric Merryfield 1883 STK Yes it was Andrew, but Carey Bales was driving the car there. Carey's Car # is 316D and he ran in the F/SA class at Chicago. So what is correct ws it the madon voyage or had the car been run and DQ'ed before. It was a great run and congrats on the fast car. I was just curios as the two responses seem to contradict each other. |
#57 |
actually eric was told he was light the first run down the track so he put 60 pds in and went the same ET and not to mention it was atleast 3 and a half tenths slow there or more so your looking at a 10.20 F/sa car fing rediculous if that is how you spell it! Lets go back to the seperate classes FI and real stock
#58 |
Liked 228 Times in 70 Posts
Mickey,
That doesn't help other FI combinations! I would just say DWA!
#59 | |
Liked 279 Times in 68 Posts
The 5.7 hemi in the Challenger is under rated by about 100 hp. How long do you all think it will take to get that little gem in line.
Greg Hill 4171 STK |
#60 |
Liked 23 Times in 3 Posts
fo real
Billy Pires 1414 STK, 1414 SS |
