Old 06-23-2010, 08:34 AM   #1
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Default Re: Nasty Vibration
Originally Posted by chris tinberg View Post
Hey mike when we first got the cavalier done we had a terrible vibration in the steering from the 1000 ft on ,we checked everything, to make a long story short we had a bad set of front tires how we found this out jason took them to a tire shop in north kcmo that balances big tires like for FWD trucks it is different than conventional spin balancers it has wheel of some sort that spins on the outside of the tire and thats how we found out the tire wasn't round from now on we always take them there to get mounted and balanced . this might not be your problem but keep that in mind for the future ,don't trust the track balancers were you buy your tires we had both front and rears checked and they told us they were ok ! good luck chris
Thanks, Chris. Even on stands, the vibration is horrible. On visual inspection, the rears don't seem to be out of balance, ie. not hopping or bouncing. I think it has to be in the driveline somewhere, but I also think we need to balance the tires once, as you mentioned. It definately wouldn't hurt and might make the ride more smooth.
Thanks again for the suggestion. Why weren't you guys at Denver?
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 06-23-2010, 05:23 PM   #2
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Mike find out anything yet? No im not coming to Tulsa. Considering going to the 3 races in 3 days S/SS combo at Belle Rose next month. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 06-24-2010, 08:17 AM   #3
Mike Voth
Mike Voth's Avatar
Got the clutch and pressure plate back yesterday. The pressure plate was out of balance by 38 grams!! We all know that these cintered iron setups warp from all the sliding, but does that usually make them out of balance?? Nothing was missing from the pressure plate, and the disc is still in one piece. Anyone ever have this issue?? The tranmission is still coming apart, hopefully tonight, but 38 grams is a TON spinning at 9000 RPM
Any other thoughts??
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Old 06-24-2010, 08:38 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Mike,
I'm sure thay told you 38 grams, but to really tell how much out it is the actual correction radius needs to be known... 38 G. 2 in from center is not nearly as much as 38 g. 8 in from center..... Still 38 G is a big number for any correction radius.
That could have knocked a little extra clearance in a few other vital parts. Rear bushing and Pilot bearing as well as all bearings in the tranny come to mind..
good luck
Adger Smith (Former SS)
Old 06-25-2010, 09:15 AM   #5
Mike Voth
Mike Voth's Avatar
The "lug" was welded just past center, more towards the outside of the hat than the inside. There was a small one on the opposite side that was cut off to balance properly. Something doesn't add up...without breaking a finger, etc., how can a pressure plate be that far out of balance?
The mainshaft appears straight, but we'll know later today for sure when we get it back from the machine shop.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Old 06-25-2010, 09:43 AM   #6
Adger Smith
Mike,
It could have something in the clutch failing and the plate be way off center.
I'm not familar with your clutch, but the old Long style and Borg & Beck I used back in the 70's would shift the pressure plate off center if a stirup or a hat hold down bolt would/was failing.
Good Luck
