Old 07-08-2010, 12:22 PM   #1
68Mustang
Liked 2 Times in 2 Posts
Default Re: question about ladder bar/shock adjustments
Jeff i was curious what your car weighs and what rate coil spring do you run in the rear
68Mustang is offline   Reply With Quote
Old 07-08-2010, 03:40 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
I would lower the front of the bars a little more. You cant adjust for a bad track. I run the same shock combo. Your ride height of the shock should be just a little more than half travel. QA-1 should give a ride height for your shock. Then install the softest spring to get the ride height.
Mike Pearson 2485 SS
