Old 10-18-2010, 07:17 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Default AOD Trans.. ever been successful?
I am thinking about building a stocker out of my mustang 5.0 and was thinking about sticking with the AOD transmission, slightly beefed up. Has anyone ever done it? Aside form Lentech Automatics in Canada, I haven't really found anyone who specializes in making these things work.
'65 Mustang SS/L & L/SA
Old 10-18-2010, 07:37 PM   #2
Chris1529
Liked 70 Times in 29 Posts
Default Re: AOD Trans.. ever been successful?
used to run one in my car. Had the trans rebuilt with a transgo shift kit and a PTC cpnverter. The trans shifted itself, I just put the selector in D. Mine was the original 84 trans which was the two piece input shaft. The 2-3 shift loses alot of rpm if you keep this type. (which I did)
I am not sure if the newer cars had the two piece input shaft. Lentech kits change then to one piece input shaft.
The trans seemed pretty tough, but I think it took alot of power to run it.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 10-18-2010, 07:46 PM   #3
Bobby Fazio
Yes I am running a good Lentech valve body now which I can shift, along with an Art Carr non-lockup converter and a good input shaft from art carr. I just want to know if the AODs are tolerable for racing or are they inefficient and too heavy. I won't be making too much hp (probably about 300?) and am not looking to set any records just want to run a few tenths under the index.
Old 10-18-2010, 10:56 PM   #4
7423
Ran an AODE in my 95 Mustang for a season. E shifted it, had a 2.84 low gear set, worked well but I know it is waaaaaaaaaay heavy with lots of extra nonsense inside that we do not need. Installing a C4 as we speak. I can tell you that a C4 is exactly 50lbs lighter than the AODE and the 8" convertor that I will run is 6lbs lighter than the 9.5" that I had in the AODE. Had the indexes been left alone, I would have stuck with the AODE. I believe the C4 should be worth .10-.15.
7423 is offline   Reply With Quote
Old 10-19-2010, 04:37 PM   #5
Swandog
I'm in a similar situation building a AOD based stocker. It will run in IHRA pure stock without issues but NHRA indexes are pretty tough. I'm not saying it can't be done but you will need to work hard to match the et of a C4. I've also read 0.10 et loss for AOD vs. C4 but haven't personally seen it. Anyhow, if you haven't already you want to head over to www.clickclickracing.com to get all your questions answered.
Good luck with your project.
Dustin Swanson
Canadian Prairies
Swandog is offline   Reply With Quote
Old 10-19-2010, 06:05 PM   #6
Chris1529
Bobby,
if you already have the lentech valve body and the one piece converter, I don't think I would spend the money to put in a C-4. Unless I was going with a full race C-4 , I wouldn't do it.
Chris Bowman
1984 Mustang GT350
Old 10-20-2010, 06:28 AM   #7
jaw8850
jaw8850's Avatar
Had Lentech AOD solid input shaft & alabama converter concepts custom converter in my 88 5.0 stock bottom end with b cam & patriot heads..ran 12.90...switched to c4 & ati converter no other changes & car ran 11.70...grant it new converter stalls at 3000 old stalled at 2000 but car is much quicker (1.67 60' compared to 2.05) but also picked up over 4 mph & is way more consistent
jaw8850 is offline   Reply With Quote
Old 10-20-2010, 08:36 AM   #8
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Less rotating mass = faster et. Run the C-4
Bob Pagano A/SA
Old 10-20-2010, 10:24 AM   #9
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Originally Posted by bob pagano View Post
less rotating mass = faster et. Run the c-4
x2
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
Old 10-20-2010, 03:03 PM   #10
Bobby Fazio
Thanks for the input.. hopefully I can unload some of this AOD stuff then.
