#1 | |
Liked 49 Times in 15 Posts
A simple fix is to drill and tap your factory inlet housing to 3/8" pipe. With a good drill press and a sharp tap it won't take you more than 10 minutes. Then you can use a very common AN to pipe adapter.
Dean Feiock -- Stock 5002 |
Made mine. drilled and tapped the -6 fitting, thread in the -8. No problems
Jason M Silver NHRA Stock Eliminator - 1278 88 Oldsmobile Cutlass 307/213 Last edited by STOCK1278; 10-25-2010 at 06:40 AM. |
