Old 10-26-2010, 03:56 PM   #1
Kevin Love
Liked 19 Times in 10 Posts
Default 2011 Stock/Super Stock Rule Changes
NHRA has rule updates for 2011 listed on NHRA.com
Quick review:
Stockers back to 1955
Valve springs in stock
Parachutes in stock (over 150)
Maximum weight limits
Gloves/neck collars for more classes
Trans shields/flexplates/flexplate shields in more classes
Wagons in SS/GT
Listed on front pages under Racer Updates
Kevin Love 5666 STK/SS
Kevin Love is offline   Reply With Quote
Old 10-26-2010, 04:08 PM   #2
novassdude
Liked 136 Times in 49 Posts
Default Re: 2011 Stock/Super Stock Rule Changes
Am I understanding this one correctly. You can not run heavier than the next lower classes Minimum weight? So there will be no more running 300 pounds heavy to slow down cars?
WEIGHT
All cars will be permitted to run on the class minimum weight, but may be no heavier
than the minimum for the next heavier class. Car can move up (lighter) one class or
down (heavier) one class. If weight is added, must be properly attached; see BALLAST.
Class and classification weight are determined without driver weight. Once classification
weight is calculated, 170 pounds is added for driver to arrive at total weight. All cars are
weighed with driver.
novassdude is offline   Reply With Quote
Old 10-26-2010, 04:15 PM   #3
Smile Re: 2011 Stock/Super Stock Rule Changes
Quick review:
Wagons in SS/GT
Terrific - I'll start building my "Black Widow" '57 Bel Air 283 / 250hp powerglide car ASAP .......Or at least when the economy changes .
Jack Matyas is online now   Reply With Quote
Old 10-26-2010, 04:18 PM   #4
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Quick review:
Wagons in SS/GT
Of much importance to you shall we say plus sized racers, or the overweight stocker/super stocker trying to avoid getting a HP hit......yet still running all out....
Eric
Eric Merryfield 1883 STK
Old 10-26-2010, 04:28 PM   #5
Stock4106
Liked 10 Times in 4 Posts
One new class has been added (AA Front Wheel). Does that mean the rumor of the factory cars in their own class goes away?
Owen S. Birkett
Stock/Super Stock 4106
Stock4106 is offline   Reply With Quote
Old 10-26-2010, 04:31 PM   #6
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Jack, me first!!!!!!
Wade O
Old 10-26-2010, 04:38 PM   #7
Chad Rhodes
i think the Max weight rule has been a long time coming. If you are heavy enough to run D/SA, you are D/SA, as long as the car fits that class, even if you did put C/SA on the sheet.
Also notice that now heim joint tie rods (bump steer kits) are legal now, after much heated debate.
Chad Rhodes 2113 I/SA
Old 10-26-2010, 04:51 PM   #8
Eric Merryfield
Looks like the VW bugs and beetles will be in SS. My dad will be glad. I like the 55 on rule a lot. Other changes that just make a lot of common sense especially on the safety front.
Let the building begin.
Eric
Old 10-26-2010, 04:56 PM   #9
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
They highlighted "NHRA approved aftermarket cylinder blocks" for s/ss..is this new for stock??
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 10-26-2010, 04:57 PM   #10
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: 2011 Stock/Super Stock Rule Changes
Do I understand correctly that now "any" valve spring is permitted, including dual springs "provided no modification to head is performed."? But that removing the "step" on Mopar heads would be considered a "modification"?
IHRA usually follows NHRA.
