View Poll Results: .031" Dykes or .043" Rings ?
.031" Dykes 41 33.88%
.043" .155" radial moly ring with lateral gas ports 39 32.23%
.043" .134" radial moly ring with lateral gas ports 31 25.62%
Other, Make suggestion 10 8.26%
Voters: 121. You may not vote on this poll
Old 01-24-2011, 01:45 AM   #37
trmnatr
Default Re: .031" Dykes or .043" Rings ?
More are using .0325" and .028" rings with gas ports. I don't think too many fast na engines are still using dykes rings. .043" is becoming "old tech".
I like the dykes but they dont last a long time. I would like to try a .031" dykes hellfire type ring with the gold finish face coating (PVD 92) from Total Seal
400 Gm block, GM nodular crank, GM camel hump heads with no intake runner porting but are bowl ported and exhaust runners polished, vic jr, solid flat tappet, flat tops with 1/16" 1/16" 3/16" rings
The engine break away torque was 17 or 18 foot pounds, constant was 14 foot pounds. The engine seals up great, making about 520-530hp my ET's. Over 250 runs without .001" change in lash with 160 seat and 400 open on std crane solid lifters. Switched to alky when he bought a dragster and left the team with the engine,,, has went as fast as 8.60/.8.70's consistently
He wanted me to maybe rebuild the engine, pulled the pan off and called me. Engine looks like new. Gets no alky in oil, rings gapped .022" / .030"+
trmnatr is offline   Reply With Quote
