#11 |
Of course on a 2bbl it is easier to activate the tilting mechanism with the throttle linkage. Don't forget to adjust the fuel mixture for WOT, not pit cruising!
Jeff Lee 7494 D/S '70 AMX |
#12 | |
Location: Trussville, Alabama-Originally from Vidalia,GA
Mark, did you happen to try the old flat washer trick between the 2 bbl and the intake. Bet Jimmy Parker can relate to those days....Not meaning he did it, but that he saw it.....Frank
#13 |
Liked 84 Times in 21 Posts
I have the intake, carb, air cleaner and heads if anyone is interested.
#14 | |
I DO know ,you can remove three little parts from a 4GC carb and pick it up over a tenth.. or so I'm told. LOL
#15 |
Hell Jack, I've got the crank out of one. Was never bored for a pilot bushing. Its also 5lbs lighter than any other 396/427 crank we have. Unfortunately it died an untimely death at the hands of a spun rod bearing
Chad Rhodes 2113 I/SA |
#16 |
Liked 705 Times in 219 Posts
Seems to me the bottom half( short block,cam, pistons, etc.) on that engine were the same as the 325 horse. the heads were one-off, about equivalent to a 71 402 head,but with a different part number, but that crank you mentioned is a cast crank. Almost all the 68-9-70-71 396/402 standard production units were cast. ('<').
#17 | |
#18 |
Liked 280 Times in 139 Posts
I don't know if this is an urban legend, about 20 years ago a guy told me to find a 335 hp. 427 crank same stroke as a 396 (cast). I believe it was 69 only no pilot bushing and was lighter than 325 396, cannot find the casting no. gsa612
#19 |
that's the crank but it was a 2bbl 396 out of a wagon (not 100% sure on the hp), may have been the same in a 427/335
#20 |
69 Full size and wagons only @ 265/265. Do not see it in any other year in my books
Danny Waters, Sr / 73 Duster "340" |
