Liked 6 Times in 4 Posts
You can spend a lot, or a little...... All depends on how long you want them to last...
I started out with a cheap 3500 lb unit off e-bay ( it is new, and I payed about 130.00). I will see how long it lasts and make my next purchase, decision based on this info....... |
I have all the stuff in my trailer as you (probably more). I finally bought an electric jack after going through several of the manual type. I bought one from a mom and pop trailer company out West on Ebay. I paid about $150 for one that I saw for up to $280 for the same exact one in other places. It is the black 3500# one with two built in lights on it. It plugs in to your 7 pin trailer hitch or you can wire it to your onboard trailer battery that powers your winch. Had it for over 6 months and no problems. Sorry I don't know the brand. Do your homework though, you can pay a lot or a little for the exact same unit! Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 14 Times in 11 Posts
I am adding an electric jack to my open trailer (has a five foot tall box)
and if the car is loaded I have trouble cranking with the hand crank (bad back) the jack costs $210 and is wired into the 7 pin plug and has a light. I don't know the name yet other than that the shop owner said he did not use Atwood jacks anymore. I will know the name when I pick up the trailer next Monday or Tuesday.
Phil Saran Parker, Colorado |
#4 | |
Sounds like the same one I got....... One thing that I took into consideration when purchasing a jack is some have a head (motor) so big you can't lower the tail gate on the truck. The style jack I got the tail gate just clears.... Last edited by rallye bob; 02-27-2011 at 07:16 AM. |
Liked 427 Times in 97 Posts
Have had good luck with Atwood Tongue Jacks!
It's strong, attractive, has a conveniently mounted light, easy to install, has an optional hand crank in the event of a battery failure (if for some reason you forget the light on & kill the battery) Wired it to a 12-volt battery on the trailer that our winch is also wired to, so we can connect & disconnect without plugging into the truck, however when the trailer is in use and plugged in, we use the12 volt source on the 7 pin plug to charge the battery while towing! (always considered this as having a "spare" charged group 24 battery available in case of an emergency) Take a look around the pit area at trailers to see what manufacturers are installing on trailers? ATC uses Atwood? |
I have been thinking about an electric jack for my 24' ATC. I was considering an Atwood. What's wrong with them?
Ed Wright 4156 SS/JA |
Liked 136 Times in 49 Posts
I wish I could get at mine to see who made it. I think it is atwood the top can lift off so you can use a crank if no power. It is around 10 years old and has always worked great. Best thing I ever added to a trailer.
I bought a 30' Classic C in '04, it came through with a "Super Jack" (built by H & H manufacturing) rated at 3500#'s lifting capacity. It has performed flawlessly, also comes with a manual crank handle if needed. I've said many times the best money I've ever spent on an option was for the electric tongue jack.
In God I trust. |
