Old 03-31-2011, 01:11 PM   #28
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Default Re: Solid Motor Mounts - Good or Bad?
Originally Posted by Lew Silverman View Post
Much as I remember (and it's been a while!), didn't the 55-57 Chevy have the rear mounts on the bell housing? Or was that just on the trucks?
I once had a Top loader in my Nova that bent the factory crossmember before I braced it, a little heavier than a muncie.
Lew
Yes, the stock 55-57 cars have the rear mounts on the bellhousing. The originals were a "rubber" style that over time got really sloppy because of leaking oil/transmission fluid. I had special steel ones made that mount in the original spots which I currently still use.
Robert,I too used to run the T-16. Took an original sidecover in one time to have a bushing pressed on the 2/3 boss to strenghthen it. They threw it out by mistake and ended up making me one out of steel. It sure shifted better.
I am looking forward to the Jerico and am on a mission to make it work while retaining my original bench seat.
Allan
55 Chevy is offline   Reply With Quote
