Old 04-10-2011, 07:02 PM   #41
Liked 5,136 Times in 1,959 Posts
Default Re: Ford and Mopar Aluminum R/E Cases??
Mark, I didn't know you were such expert on on the rule book. I should have consulted with you before I built my car.
And since you are the expert here, can I replace my center section with an aftermarket as long as it is steel, even though there is no mention about aftermarket cases. Remember if it does not say I can, it means I can't.
Ken, No expert , that's for sure. I don't think anyone could be .
I've been around NHRA for over 40 years now, and I just have an idea how they think most of the time. I do think that they put some of the vague, ambiguous language in there just to give themselves wiggle room .
As to your question, the aftermarket steel case is close enough to OEM in weight and density, that it's considered a replacement part, similar to a Moser 12 bolt (Technically not OEM either).
I got busted at Gainesville years ago, for having a Moroso aluminum water pump on a 283 Stocker . I painted it black and all, same as the engine. I knew it wouldn't fly if it was ever spotted. I happened to have a cast iron spare in the truck, ready to go on . LOL
Old 04-10-2011, 08:07 PM   #42
Liked 17,061 Times in 1,555 Posts
I think your forgetting the golden rule, if it does not say you can, it means you can't.
Mark, lets just say I don't agree with any of your interpretations of the rules that I mentioned, especial the one that effected me. Oh yes, that's exactly what I thought you would say, I just wanted to see you type it.
Jeff, one more time, NHRA told me it is not a performance advantage, that argument is over.
Old 04-10-2011, 09:01 PM   #43
Liked 10,846 Times in 2,254 Posts
Bill dont forget drive by wire!
I'm going to get one of the new 8 4/4 so i can get better gear selection and rear suport on the pinion...
Old 04-10-2011, 10:30 PM   #44
RJ Sledge
Liked 292 Times in 92 Posts
Larry does a Mopar 8 4/4=a 9" Ford??
RJ
RJ Sledge is online now   Reply With Quote
Old 04-10-2011, 10:33 PM   #45
7423
You have mentioned that you want a clarification of the rule. Who would you like to hear this from? Does NHRA employ someone who has the authority to "clarify" something in the rule book?
7423 is offline   Reply With Quote
Old 04-10-2011, 11:52 PM   #46
Phillip marvetz
Phillip marvetz's Avatar
RJ
Yes
2009 V/SA Record Holder
Old 04-11-2011, 12:14 AM   #47
Jeff Lee
Jeff Lee's Avatar
Really? Then why is the aluminum center section not allowed at present? Apparently somebody disagrees. Must be the "other guy" at NHRA.
Jeff Lee 7494 D/S '70 AMX
Old 04-11-2011, 07:47 AM   #48
RJ they do look the same and all the parts interchange.
Old 04-11-2011, 11:25 AM   #49
RJ Sledge
Larry
Thanks I believe that I'll try one of those Mopar Aluminum units in my car. They still pay don't they??
RJ
Old 04-11-2011, 12:34 PM   #50
Greg Hill
Liked 279 Times in 68 Posts
This is just another time when they don't follow their own rule book.
Greg Hill 4171 STK
