#11 |
Plus as mentioned, all 260 blocks use the oddball 5 bolt bellhousing, which means that the later C4`s won`t bolt up, and until recently, a 5 bolt SFI scattershield was unavailable, but Quick Times does now list one. You could convert the Falcon to a 65, but even then, I believe that the 289 in the Falcon is 2 barrel only.
#12 |
You could always sleeve down a 289 block if it was a good combo..
It's not!
#13 | |
Banned
#14 |
Liked 7 Times in 6 Posts
Can't make 64 into a 65 was totally new body?.... um, no, 64 and 65 falcon, same body, different grill and tail lights
#15 |
Liked 3,205 Times in 977 Posts
What classic looking cars though. Any of you guys know if a 9 inch tire will even fit?
#16 | |
Another difference is the body side moulding. 64's is wider apart than the 65's. Jeff
Street legal 64 Falcon Sprint with 410W ![]() Stock - Super Stock fan |
