i have a 73 340, have been told i can use a newer smaller starter from a truck, anyone know of the correct part, i need the year and model of vehicle, thanks, Keith
Liked 263 Times in 68 Posts
New starter from Mancini Racing.
Item# MRE644 $129.95 You can buy a stock rebuilt starter for a 1998 Dodge pick up with a 318 or 360 from your local auto parts store.
John Dinkel 3295 STK |
Liked 68 Times in 41 Posts
any 318 or 360 starter of truck from 92 to 2000
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
thanks guys, thats what i was looking for, headed to parts store tommorow...
If you need cross -reference # 56027702 ac is Chrysler part number
Chris |
Liked 138 Times in 51 Posts
I've found that some OEM style mini-starters need a little clearancing. The area on the block has been around a hole that is in the bottom of the bellhousing area. I believe a spot there is usually machined at an angle, but for some reason, some starters still hit. Maybe it's something with slightly different starter bodies......just in case you run into that.
got one for a 94 pickup, was 64 dollars. the one for a 98 pickup was 98 dollars. looked like the same starter, still it fit and worked great, thanks for the replies
