Old 06-01-2011, 02:35 PM   #31
Default Re: 727 W/ 904 internals
Originally Posted by Phillip marvetz View Post
Mark,
It's a fact that they were using a modified chevy case, Why? I don't know and don't really care.
PM me with the details... I'll investigate it.
Yes , I agree . Everybody gets an Ultra Bell...or nobody!
Old 06-01-2011, 06:07 PM   #32
Rory McNeil
I have also seem many GM automatics that had both the Chevy and the "BOP" bellhousing patterns.
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 06-01-2011, 08:32 PM   #33
Bill Edgeworth
Phil,
Like Mark said I have no idea why a Pontiac guy would do this. For the amount of work it would take it would be easier to stuff the guts of the transmission into a BOP case.
All the same trans used in performance applications the Turbo 400, 350, metric 200 and PG were all available with a BOP case and there are lots of cores out there. And as Rory said there is also the dual pattern cases.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 06-01-2011, 11:03 PM   #34
Phillip marvetz
Phillip marvetz's Avatar
Maybe the chev case is stronger than the BOP?
Anyway's I wasn't trying to pick on the guy's that did it, Just knew that it had been done and that it was protested and NHRA did nothing about it.
Now back to the subject,
Mark, Can I bolt a 727 tailshaft to a 904? I don't want to build a new driveshaft, LOL
2009 V/SA Record Holder
Old 06-02-2011, 12:27 AM   #35
Don't know that one .I'm a GM guy, and an occasional C4.
I'm sure someone here can tell you more...Maybe Alan?
Old 06-02-2011, 02:56 AM   #36
GTX JOHN
Phillip: I Do not believe that it would be very possible or economical to exchange Tailshafts......................................
Trans output shaft are different in length and diameter as I recall andmaking
a output shaft would be a small fortune. Both tail shaft have rear mount in same place and take same transmission cross member . The yolk is twice
the size on front of drive shaft on 727 than on 904. Nevertheless , it would
much easier to make a new drive shaft or rework a stock one than modify
the transmission!
I am sure that there are some transmission builders than can give you
better advise than I can.................I have not rebuilt my transmission since
the 80's. More effective to just cut a check to Pro Trans and cheaper
in the long run with my skills.
Phillip: Will answer your E mail tomorrow.
Old 06-02-2011, 08:10 AM   #37
Jeff Goss
Jeff Goss's Avatar
I think this was the Cadillac automatics. I have seen one in person.
Jeff Goss is offline   Reply With Quote
Old 06-02-2011, 11:46 AM   #38
Mark Maez
Mark Maez's Avatar
I just sent an email to NHRA requesting we be allowed to use an adapter, If enough of us do this we may get somewhere.
Phil,
send me the info I'll send a request also
Mark Maez is offline   Reply With Quote
Old 06-02-2011, 01:55 PM   #39
Rory McNeil
I don`t know Jeff. I`ve seen the multi pattern Turbo 350`s & 400`s in a number of none Caddilacs. Not sure what the reason was, other than maybe streamlining inventory?
NHRA 6390 STK
M/S 85 Mustang
Old 06-02-2011, 02:03 PM   #40
Liked 1,892 Times in 423 Posts
Never tried that, I don't have the parts here to compare, but I doubt it.
Like Mark, I do a lot more GM stuff than anything else, I can do all sorts of tricks with GM stuff, from PowerGlides to the latest stuff. The Ford and Chrysler stuff I can build really nice race transmissions with, but "trick interchanges" are out of my league.
