#1 | |
Liked 3 Times in 1 Post
Wade O |
Don't know if it's the best, but we're using an XS Power "Intelli-charger". Charges both 12V and 16V AGM IntelliCharger compatible with 5A, 15A, and 25A(25A max) output. Three charging modes and LED indicators with ammeter to monitor status (grabbed that off of their site). It's part number 1005 if you want to look into it yourself.
Phil Hudlow 6678 (S/C, S/G, ET-PRO) |
Liked 4 Times in 2 Posts
I have a Black & Decker 25A-10A-2A Smart Charger. Have had zero problems with it. Also keep a 0.75A maintainer on it during the week.
Also, the Black & Decker unit will pop up error codes if there is a short in the battery or there are other problems. Another thing I really like about it is that if you hook it up backwards it will not charge and the lead is not hot until it knows it is hooked to a battery correctly and you set the charger.
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
