Old 07-08-2011, 07:46 AM   #11
Knocky
Default Re: Automatic Transmission Cooling
Anyone run a Dearle deep steel pan w/ airflow cooling tubes ? Any clearance problems? Kinda heavy, but Figured it would be good insurance if bracket racing ...thanks, Norris
Knocky is offline   Reply With Quote
Old 07-08-2011, 09:45 AM   #12
Paul Precht
Paul Precht's Avatar
Liked 306 Times in 115 Posts
Don't plug the line feeds on a torqueflite as the rear shaft support gets it's lubrication from there.
Paul Precht is online now   Reply With Quote
Old 07-08-2011, 11:08 AM   #13
Phillip marvetz
Phillip marvetz's Avatar
Hi Jim, Your best bet for a drip free trans is to loop it. Kelly made 15 runs last Friday at the track rental and the hottest the trans got was 180. A stocker is never going to be in a position to take that kind of abuse.
2009 V/SA Record Holder
Old 07-08-2011, 11:28 AM   #14
Jim Wahl
Jim Wahl's Avatar
Liked 682 Times in 128 Posts
Thumbs up Re: Automatic Transmission Cooling
Jim,
As you know I have a Pro Trans 904 also. They will tell you all you need is a loop. Mine came with a copper line loop. No problems. I change the fluid every 30 runs and have a reusable/cleanable filter. Fluid levels are very important in these trannys! Jim
2009 D2 National Open Stock Champion
1981 D2 West Palm Beach LDRS SS Runner Up
Old 07-08-2011, 11:52 AM   #15
jmcarter
jmcarter's Avatar
Liked 3,099 Times in 954 Posts
Thanks guys....I'm looping and changing frequently. And yes Jim, after Reynolds last year I keep a real close eye on the level!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-08-2011, 01:09 PM   #16
Jim Wahl
Jim Wahl's Avatar
Roger that! Jim
Old 07-08-2011, 04:14 PM   #17
Liked 5,004 Times in 1,904 Posts
Real world story;
I was at Atlanta Dragway on a hot humid night years ago, running a friend's SBC, PG Camaro. He had a trans temp guage and no cooler, and it was staying around 200 * . I was going rounds , with not much time in between. In the semi's I couldn't run the dial and lost. The car didn't spin, so I looked at the gauges, and the trans was at 240.
I always put a cooler up front on my Stockers. You spend so g.d. much money on them anyway, why not?
Bottom line: I'd listen to Myron or anyone else here who goes many late rounds in hot, humid weather.
Old 07-08-2011, 05:28 PM   #18
jmcarter
jmcarter's Avatar
If you go rounds with a looped trans then you need to start putting a blower under the car as soon as possible...you'd be amazed how much heat that pulls out of a trans. I did that cooler or not "back in the day" when I was bracket racing quite a bit.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-09-2011, 07:19 PM   #19
04GTOMan
hey guys I'm a newbi at this What do you mean by a loop and heat sink?
04GTOMan is offline   Reply With Quote
Old 07-10-2011, 12:13 AM   #20
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: Automatic Transmission Cooling
Line in & line out are the same line...loop
