Liked 10 Times in 10 Posts
1968 NHRA Indy Nationals
September 1968 SS/EA Class Championship Lance Hill (in the Lance Hill/Dick Arons, 1968 SS396 Camaro 396/325) versus Bob Lambeck (in the Dick Landy 1968 Dart 440/375 HP) ![]() |
Mungo Jerry,
1968 Numbers; 1968 Dodge Dart GTS 440,,,,, Weight;,,,,,,,,,, #3208 lbs. Engine;,,,,,,,,,,, 440/375HP Wt/Hp,,,,,,,,,,,,,,8.55 wt/hp Carburetor;,,,,,,Carter 750 AVS (1 11/16" x 1 11/16") Compression;,10.1 -1 (flat top pistons) Intake;,,,,,,,,,,,,,,,Cast Iron Dual-Plane / Low-Riser,,,, (Cast #2806178) Heads:,,,,,,,,,,,,,,2.08 Intake / 1.74 Exhaust, Open chamber 79.5 cc's,,,, (Cast #2843906) Camshaft;,,,,,,,,,.455 Intake Lift / .480 Exhaust Lift,,,, 268*/284* Duration,,,,46* Overlap Cam Type;,,,,,,,,Hydraulic Lifters, Non-Adjustable rocker arms 1968 Class;,,,,,SS/EA (Super/Stock Only) Dodge did not build enough cars to qualify for B/SA. Automatic only cars,,, Oddity,,,,,,there were only '6' 1968 Dodge Dart GTS 440 cars built at the time of the1968 NHRA Winternationals, yet they were legal entries,,,, ![]() Last edited by Paul Ceasrine; 08-16-2011 at 10:42 AM. |
The Edelbrock Model #CH4B, utilized in 1968 for the 440's in
Super Stock. An aluminum Dual-Plane High-Riser ![]() And the stock cast iron manifold; ![]() Last edited by Paul Ceasrine; 08-15-2011 at 04:56 PM. |
Ed,,
1968 SS/EA Class Competitors; 1968 Dodge Dart GTS 440/375HP,,,,,,,,,#3208 lbs. = 8.55 wt/hp (note A) 1968 Camaro SS 396 396/325HP,,,,,,,,,,#3306 lbs. = 10.17 wt/hp (note B) 1968 Camaro SS 396 396/350HP,,,,,,,,,,,#3318 lbs. = 9.53 wt/hp (note B) 1968 Chevelle SS 396 396/375HP,,,,,,,,,,#3567 lbs. = 9.51 wt/hp (note C) 1968 Cobra-Jet Mustang 428/335HP,,,,,,#3267 lbs. = 9.75 wt/hp (note D) 1968 SS/EA Class weight break,,,,,, 8.70 - 9.47 wt/hp (note E) Note A: Though the 68' Dart GTS 440 had a weight/horsepower factor under 8.70, the NHRA classed the car in SS/EA. Later, the NHRA would re-factor the 440/375 HP to 365 Horsepower, and then again to 356 Horsepower. Note B: The difference between the 68' Camaro SS 396 396/325 HP and 396/350 HP engines was the camshaft, which meant no difference in Super Stock. Later, the NHRA would re-factor these engines to 360 Horsepower for Super Stock. Note C: The 68' Chevelle SS 396 396/375 HP was classed in SS/EA. The 396/375 HP was later re-factored to 390 Horsepower. Note D: The 68' Cobra-Jet Mustang 428/335 HP was classed in SS/EA. The 428/335 HP was immediately re-factored to 355 Horsepower by the NHRA for the 1968 season. Note E: In 1968, this class was car specific, and did not only go by the wt/hp factor. Last edited by Paul Ceasrine; 08-16-2011 at 02:31 PM. |
Liked 12 Times in 12 Posts
Looks like someone's been busy the last several posts, good info & stats Paul C. Did you find out anymore info or photo's on those other 6 built 440 Dart GTS for SS/EA.
