Old 08-21-2011, 01:56 PM   #1
rod
Liked 20 Times in 15 Posts
Default 9" ford ?
for some strange reason the pinion support 'O' ring is leaking. is it possible to pull the support out, replace the 'O' ring and reinstall the support? it would certainly be quicker to the 5 support bolts than to have to pull the third member.
i run a 5.67 gear so the pinion is small with 6 teeth
any help will be greatly appreciated.
thanks rod in AZ
rod is offline   Reply With Quote
