Old 09-04-2011, 05:58 PM   #101
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 17 Times in 7 Posts
Default Re: pics from INDY... 2011... from sheehan
The "silver cooling machine" used by Gary Richard is this very unit and it's called "cold shot"
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 09-04-2011, 06:19 PM   #102
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Wade Mahaffey
Any idea how much it costs?
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 09-04-2011, 06:30 PM   #103
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
If you have to ask............................................... .................:>):>):>)
Former NHRA #1945
Former IHRA #1945
T/SA
Old 09-04-2011, 06:56 PM   #104
FED 387
Liked 333 Times in 180 Posts
Question Re: pics from INDY... 2011... from sheehan
those units pictured probably "list" for at least $2500 to maybe as much as $4000 maybe even more depending on who ya got it from as well as the extras---the generators pictured add in another $800 to $1900-----close enuf for ya ???
Old 09-04-2011, 06:58 PM   #105
troublemaker427
troublemaker427's Avatar
Liked 64 Times in 23 Posts
They are easy to make with a cooler and a submergible (sp?) pump. They've been used in other "heads up" drag racing for years.
Jody Aberts
Troublemaker2
1966 Fairlane 427
Old 09-04-2011, 06:59 PM   #106
James Perrone
Liked 1,829 Times in 427 Posts
You can build one for less than $150.00.
Just Think!
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 09-04-2011, 07:09 PM   #107
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Don't forget to add the price of the golf cart and the extra crew necessary to get this stuff to the lanes when you need it........Pretty hard carrying a chiller machine full of ice and water and a generator from the lower forty.....
Do they at least still give out a trophy for an Indy class win? Cause than it's definately worth it
Rich Biebel
S/C 1479
Stock 147R
Old 09-05-2011, 12:09 AM   #108
Wade Mahaffey
The silver unit "Cold Shot" is somewhere around $11-1200 and comes with the one way valve for the upper radiator hose. The one way valve has "Jiffy-Tite" quick disconnect fittings for easy operation. The units hold twenty-two gallons of water, however most folks are only using about half of that. The units are made one at a time and can be custom tailor made to fit your storage or operational needs. The inner vessel and outer cabinet are separated by insulation to keep the water as cold as possible.
Wade Mahaffey
Old 09-05-2011, 01:29 AM   #109
Marine One
Marine One's Avatar
Can be done much easier, cheaper, and smaller. Use a NOS size bottle full of liquid CO2 (liquid dry ice). Just make a heat exchanger type of manifold for the fuel to run through with the liquid CO2. You "ice down" the fuel in a matter of seconds in the staging lanes.
Marine One is offline   Reply With Quote
Old 09-05-2011, 09:22 AM   #110
Andrew Hill
It is impossible to get liquid CO2 (without a significant pressure change), it goes directly from solid to gas, and vice versa. Liquid nitrogen is a lot colder plus it can be stored at normal pressure. However, -200 C might be a little bit too cold lol
3207 D/SA, C/ED
