Old 09-24-2011, 01:06 PM   #6
Liked 5,129 Times in 1,956 Posts
Default Re: SBC block filling ?
Originally Posted by rod View Post
i have a 60 over 327 to assemble. i would like to fill [hard block or?] this block to the bottom of the water pump holes. i understand you can put a plastic tube in the water jacket to use the lower block drain.
if anyone has personally done this, would you either explain here in detail or e-mail me.
also what brand is the best?
thanks rod in AZ
hugunin@frontiernet.net
If you fill to the bottom of the w/p holes, then you don't need block drains. The water will run right out the front. Just pull the lower hose.
