#12 |
Liked 10 Times in 10 Posts
Gene,
Differences between the 400/366 HP 'Ram Air II' and the other 400 engines. 'Ram Air II' 400/366 HP,, @ 5400 RPM (Tach red-line) 400/350 and 400/360 HP,,,,,@ 5100 RPM (Tach red-line) The 400/366 HP 'Ram Air II" , 4-Bolt main block, (casting #9792968) The 'Ram Air II' utilized; * Nodular Crankshaft * Special Arma-Steel connecting-rods * Forged pistons * Re-designed cylinder heads (w / round port exhaust) * High-lift camshaft * Up-graded valve train * Re-jetted carburetor * Revised distributor curve * Stream-lined exhaust manifolds * Ram-Air induction (dealer installed) * 4.33 Gears * M-21 Close-Ratio 4-Speed or TH-400 Automatic. Last edited by Paul Ceasrine; 10-22-2011 at 11:44 AM. |
