I'm sure you have probably heard this before, but local track rules override sanctioning body rules, every time. Find out what the particular track wants for the particular event. The sanctioning body rulebooks are at least good for leveling uneven table legs, as long as you get a hard copy. Take care. Tom Worthington.
I'd quit before I'd b*yback. |
Liked 21 Times in 6 Posts
Bill I can probably take care of you in time for race give me a call Monday with car info if you want 217-454-5289
Liked 4 Times in 1 Post
Division 1- all racers who run 9.99 or quicker , running @ an Summit ET racing series Must have oil retenion device starting in 2012 .
Liked 359 Times in 135 Posts
Bill, I think you will find that D.R.E. can make you one that fits properly and will come off and on the engine with ease. We pulled the heads on my sons car yesterday and wanted to remove the diaper because of the water and antifreeze mix that would run down the block. Four bolts and it slid right off. Tom. D.
even tho your car doesn't run in the 9s , you could benefit from the retention devise , may keep fluid from getting to the rear tires,
![]() I going to have to make something for mine , a 73 duster with motor pulled back home brewed rack n pinion setup, something D R E most likely wont have made up ? |
Dennis give me a call you might be suprised.If we dont have on shelf we can make it call 217-454-5289 Thanks
thanks for the input dennis, will have wife call you soon...keith
