Liked 123 Times in 11 Posts
I believe the foam is intented to prevent sloshing, since we go straight (no turns under a load) it is less than critical.
Now as far as sloshing backwards that is why there is a sump and the pickup in the rear. I do not know what positive purpose it serves in a drag car? I have never run one in any of my cars for the past 22 years and have never had a problem. Makes changing fuel at events easier from the standpoint of no cross contamination of fuels, thus failing fuel check. The fuel should be stored in a cool place over the winter whether it is in the fuel cell or the fuel container. Fuel has no feelings and it does not know where it is being stored. I leave my C12 in the fuel cell sealed up at 40 degrees, (my shop or garage is not heated) lol Never had a n issue at the first race of the year due to I believe being sealed and keep out the sun in a cool environment. I am open to any insights that would help performance or safety?
Joe DeMarzo 1317 STK |
Liked 69 Times in 33 Posts
The foam is primarily there to reduce the risk of the cell exploding. If a spark causes ignition of the fuel, the foam creates an impediment to rapid progression of the flame front. Or at least that's how it works in the military applications that the design came from. For that reason the foam should stay for safety. The reduction in sloshing is an added benefit.
Jeff now that makes sense, thanks.
Guest
Posts: n/a
I know in NASCAR they use it to keep the fuel from getting airated from slosh and vibration. I had it in my GTO for years. I never failed fuel check once after changing the fuel over. I never saw the advantage of taking it out..
Mr. Kempton is correct , the foam is in the cell to impede an explosion if you should be unfortunate enough to crash . The fuel cell and foam insert was developed for race cars in the early 60s by Firestone to help prevent driver death and injury from fire . The foam may have some effect on fuel sloshing ( which probably wouldn't matter very much anyway ), but that's not why it's in the cell .
