Old 12-21-2011, 03:56 PM   #1
Default Re: Q-jet and Holley
Originally Posted by vic guilmino View Post
i removed a 780 holley and
i put a q-jet on my 429 ford
same mph but et was .2 slower
carb when very rich in the first 100'
need help with that
Vic, does your carburetor have the little air deflector on the top behind the choke horn? Often you find that the combination of a slightly high float level and that little sheet metal deflector not being there will allow fuel to splash out of the bowl vent and into the secondaries.
If you do not have it, the best book for the Q-Jet racers may possibly be the book Doug Roe wrote, it's available from HP Books.
http://www.amazon.com/Rochester-Carb...4497285&sr=1-2
Old 12-21-2011, 08:38 PM   #2
Ed Wright
Ed Wright's Avatar
The two holes above the rear upper throttle blades may need restricted. On larger engines they can often be plugged. They act similar to an accelerator pump for the secondaries. Might try tape over those holes for a pass to see how it acts. If it stumbles with them plugged, you may need to restrict them.
Ed Wright 4156 SS/JA
Old 12-22-2011, 08:54 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
I have used toothpicks in the holes.
Adger Smith (Former SS)
