Old 12-30-2011, 09:58 PM   #11
Barnstorm
Barnstorm's Avatar
Default Re: 1962 Mopar 383/343 HP 'Stocker'
We've toyed with idea of running one in SS. With an intake and some heads.....
Old 12-31-2011, 08:35 AM   #12
Paul Ceasrine
Liked 10 Times in 10 Posts
Joe Kenney
Hopewell Junction, New York
'The Trick Tank'
1962 Dodge Model 440, 3-Seat/9-Passenger Station Wagon
383/343 HP
* Set '7' National Records with this car.......
1969
* G/SA,,,,,,,National Record Holder
* Top 5 Points Leader 'NED 1'
* G/SA Class Winner,,,'First Annual' Eastern Canada Can-Am Championship
* Stock Eliminator Champion,,,,'First Annual' Eastern Canada Can-Am Championship
1970
* H/SA,,,,,,National Record Holder,,,,,, (110.99 MPH)
* Top 10 Points Leader 'NED 1'
* Stock Eliminator Champion,,,'NED 1' Stockers Bonanza (Dover Drag Strip)
* H/SA Class Winner,,,,,,Indy Nationals
* Stock Eliminator Semi-Finalist,,,,,Indy Nationals
* SuperNationals,,,H/SA Representative (Semi-Finals of Stock Eliminator)
1971
* H/SA Class Winner,,,,,Summernationals
* Third-Round Stock Eliminator,,,,,Summernationals
Old 12-31-2011, 01:21 PM   #13
Frank Castros
We know Jimi Vignogna owns the Behemoth but where is the Trick Tank today?
Old 12-31-2011, 05:11 PM   #14
Paul Ceasrine
1970 Photo
Dover Drag Strip
Big Stockers Meet in 1970,,,
"NED 1 Stockers Bonanza'
A ton of New Jersey Racers headed up to New York to participate in this Big Money Event.
64 of the top Northeast Stockers attended.
Championship Run,
"Banana 1", 1957 Chevy Model #150, 283/250 HP (Class M/SA),,,,,Frank Iaconio
versus
"The Trick Tank", 1962 Dodge Model #440 Station Wagon, 383/343 HP (Class H/SA),,,,Joe Kenney
National Records at the time;
M/SA = 13.50
H/SA = 12.55
Old 01-01-2012, 02:06 PM   #15
Paul Ceasrine
Dave,
The 383/343 HP engine was an 'early-Chrysler Race Motor', developed in late-1962,,,,,,,for the Dodge Polara 500.
It could not be ordered as an engine option in the 1962 Dodge.
It was strictly an 'over the counter' performance parts bolt-on application,
to be fitted on the 383/330 HP engine.
A few (not many) of the 1962 Dodge Polara's and 1962 Station Wagons were equipped with the 'special order' 383/330 HP 4-Barrel engine,,,,,,
also known as the 'police pusuit package'.
Included were;
* Camshaft ((Mechanical),,,(Lift .445 Intake / .445 Exhaust,,,,, Duration 294*,,,,,, Overlap 55*)
* Solid Lifters
* Adjustable Rocker-Arms, w/special locking-nuts
* High-Strength Steel Pushrods
* Chrysler 300-J Cylinder-heads (Casting #2402557) (Closed chamber 66.5 cc, with 2.08 Intake valves and 1.74 Exhaust valves)
* High-Rate Valve-Springs w/damper (100 lbs. w/valve closed,,,,,,199 lbs. w/valve open)
* High-Strength Valve Spring Retainers
* In-line Dual-Quad Cast Iron Intake Manifold
* Twin Carter AFB carburetors (500 CFM) (1 7/16" x 1 9/16")
* Special High-pressure 3-valve fuel pump
* Dual-point distributor
* Special Long-branch exhaust manifolds
Note: In May 1966, the NHRA approved the 383/343 HP engine combination for the Plymouth 'Sport Fury' and Station Wagon.
Note: In 1967, the NHRA permitted the use of the 1967 440/375 HP (#2780915) 'Hi-Po' cylinder heads on this engine.
Old 01-01-2012, 08:39 PM   #16
Chuck Norton
Liked 89 Times in 19 Posts
The earliest 383/343 example I can remember in Division 7 was a '62 Dodge driven by Jim Johnson (not THE Jimmie Johnson) of Hermosa Beach, California and later by Joe Ross. I recall that it was run regularly in 1963 and was a record holder in 1964 (see attachment). I believe that it was a Polara 2 dr. hardtop and I'm sure that it had bucket seats.
Name:	1964 Records.jpg
Chuck Norton
Chuck Norton is online now   Reply With Quote
Old 01-01-2012, 09:00 PM   #17
Paul Ceasrine
Chuck,
The mid-year (1962 1/2') 383/343 HP in the Dodge Polara 500
and/or Plymouth Sport Fury combination knocked off another Mopar
for B/SA in 1963.
In early-1963, the 'Hot Combination' for B/SA was the 1961 Plymouth Fury 'Hardtop Coupe' with the
'Optional Dodge Engine' (413/375 HP 'Cast iron In-line Dual-carbed engine).
But by mid-year 1963, the secret was out, and the 'lighter' 383/343 HP cars were out-running the 'bulky' 1961 Plymouth's.
Old 01-02-2012, 01:00 AM   #18
treessavoy
Liked 4 Times in 4 Posts
Paul,
Was the 413 with the two inline fours ever a viable combo or raced by anyone?
JimR
Jim Rountree
Old 01-02-2012, 02:31 AM   #19
Hemi Moose
Liked 12 Times in 12 Posts
Didn't Don Garlit's run a 62 Dodge with a 383 motor with inline carbs on it or was that a 413 with inline carbs, I'm not sure.
Old 01-02-2012, 02:43 AM   #20
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: 1962 Mopar 383/343 HP 'Stocker'
Didn't Dob Garlit's run a 62 Dodge with a 413 motor with inline carbs on it or was that a 383 with inline carbs, I'm not sure.
Dob Garlits????? I'm glad I'm not the only one who suffers from "Fat Finger" syndrome!
Danny Durham
