Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 01-27-2012, 04:49 PM   #30
art leong
Default Re: Competetive 4-cylinders in Comp?
Originally Posted by Axis Racing View Post
Let's not argue the virtues of RWD or FWD since it's a moot point if you can't get a car down to minimum weight for the engine size if it's a RWD conversion @ 164"...
I'm not familiar with the type of car you are planning on running. But on my Neon trans is 60 pounds heavier than an stock A727 trans, my axles are heavier than a lightweight driveshaft. And I don't know exactly what my rear axle weights granted it is a lot lighter than a lightweight rearend.
I would gladly give up the weight. To use any gear ratio. Plus any tire (right now I use 20" tall tires that look like doughtnut spares). The highest I cross the finish line is 7200. My motor should make power past 8500.
The reason I don't turn the motor sideways (LOL) is the expense. And the index.
Art Leong 2095 SS
