Liked 10 Times in 10 Posts
The 1962 Pontiac SD-421 (Early-version, up to March 1962)
Engine; 421/405 Horsepower Transmission; Borg-Warner T-10 4-Speed Cost; $5000 Prouction Numbers; * Catalina Hardtops,,,,,,,,,,,,,,,139 * Catalina Sedans,,,,,,,,,,,,,,,,,,,,24 * Grand Prix Sport Coupes,,,,,16 * Total Built,,,,,,,,,,,,,,,,,,,,,,,,,,,,,179 Purpose built from air-cleaner to oil-pan as a 'Certified Super Stocker'. *The 421 Super-Duty featured a beefy 4-bolt main block, with a forged steel crankshaft. * 11.0 - 1 compression Mickey Thompson forged aluminum pistons. * Special Heavy-duty connecting rods * 8-quart wide-sump oil pan * Agressive McKellar #10 camshaft (.465" Intake lift / .465" Exhaust lift , Duration 308* Intake / *320 Exhaust) * Solid lifters * 1.65 Ratio Rocker-arms * Big-port cylinder heads (Casting #540306) (w/66.8 CC Chambers) * Activated big-valves (1.92" Intake / 1.76" Exhaust) * Twin Carter AFB Carburetors (500 CFM) * Aluminum dual-plane intake manifold * Cast-iron long branch exhaust manifolds Additional track-ready Super-Duty fare included various optional lightweight body parts. * Aluminum hood * Aluminum front fenders * Aluminum front bumper * Aluminum inner fenders * Aluminum radiator brackers * Aluminum exhaust manifolds Available in 1962, was a 'special frame' that featured perimeter rails cut out to transform rectangular tubes into channel rails. Last edited by Paul Ceasrine; 02-01-2012 at 11:08 PM. |
Liked 12 Times in 12 Posts
And a couple of Super Duty '63 Tempest station wagons...
![]() ![]() Last edited by Hemi Moose; 02-02-2012 at 07:30 PM. |
#3 | |
. Last edited by Hemi Moose; 02-02-2012 at 07:31 PM. |
The information states,,,,,,,,,,
1963 = Swiss Cheese 1962 = Modified rectangular-shaped frame rails, to channel-shaped. NHRA lists the 1962 Lightweight Catalina SD-421 at #3608 lbs., I believe. |
Aluminum Cast Iron Exhaust Manifolds
Banned
I get it.
However if Smokey Yunick had anything to do with it back then, that alloy could exist! lol |
