Great idea Jeff! That would keep racers from hiding behind the circled R in the window.
I'm still not sure what to think about record runs not counting to ASHFS. I wouldn't want to see somebody set a record @ 10.00 and then watch them dial 10.50 for the rest of the weekend.
Jeff Lee 7494 D/S '70 AMX |
Liked 184 Times in 113 Posts
Suggested this to Mike Baker at IHRA
Not enough Records are being set at an IHRA Meet. More Records set will add more credability and competition to IHRA. Create a Mobile Inspection Center - IHRA sends a designated inpector. Which may include other racers.. Inspectors go to a designated location. Such as a Dealership, Local Airport, Large Garage. Preferably Covered in the even of rain. Date Set and Racers Invited. Bring Engine or Whole Car. Get inspected, engine or car that pass get a Certified Seal of Inspection. Then the engine is sealed. Cars wanting to set records at a Meet will only need normal pre-race inpection. Then weighed after a run. If there are any discrepencies they have to get corrected. If the infraction can be corrected fairly quickly. The part gets reinspected and passed if correct. Such as a 1 Thousands-off Stock Mustang Valve. Spending several hours on a car on a non race day will make racing more fun. No more driving hours to a race to get busted for a minor infraction. Catch them early and no worry ! Feedback ?? Dan Last edited by Dan Fahey; 02-23-2012 at 02:42 PM. |
Liked 2,343 Times in 465 Posts
If you want to increase car counts at opens how about during qualifying and record runs no ahfs. Then during eliminations count the runs. This would give a lot of guys who like to go fast a chance to show what they have. And if there is a record that you think you can set but it's to close to getting hp. You can step on it and give it a try. Barry
Liked 13 Times in 9 Posts
IHRA already does the "inspect and seal" routine on non-race days, typically on the Friday of a Sat-Sun event. Sealed motors are accepted through the end of the racing season. The following year you must go through the process again.
RE: AHFS. The whole point of the AHFS is an attempt to apply realistic factors to engines. If you negate the AHFS at any time, then there is no system. The fact that people slow their cars down to avoid getting HP means exactly what that implies: the engine is not factored properly. As I've said for many years, take the incremental data that's been collected for years and factor ALL combinations once right now, get everybody in the proper classes, and then you can virtually do away with the AHFS, and y'all can go let it all hang out. (until the next rule enhancement or round of superceded parts)
#5 | |
Liked 574 Times in 212 Posts
#6 | |
Liked 1,880 Times in 422 Posts
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 02-26-2012 at 09:43 AM. |
Liked 282 Times in 103 Posts
