Old 02-29-2012, 01:07 PM   #1
Mike Gardner
Default Weight Dist. Bars, Snap up Brackets, Trailer parts
Cleaning out parts room:
5 sets of Reese Trunion style 1200LB Weight Distributing Bars. New only $50.00 per set.
5 Used snap up brackets for weight dist. hitch. $10.00 each
We also have assorted enclosed trailer exterior trim and aluminum sheets to move. No white sheets left, mostly black, gray and silver.
Come by and pick up or we can UPS.
Mike G
703 754 4611 shop
703 675 4479 cell
Mike Gardner is offline   Reply With Quote
Old 02-29-2012, 02:04 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: Weight Dist. Bars, Snap up Brackets, Trailer parts
mike---ya got a p number on the trunnion bars please??? these are the round bars not the flat ones correct??? what is UPS to zip 60047?? Thanx FED 387
Old 02-29-2012, 05:35 PM   #3
Mike Gardner
For the record, Cequent towing owns Reese, Draw tite and Hidden Hitch and this first set is a Hidden Hitch #111440. UPS is $29.00 bucks. Let me know.
By the way, it is a flat bar "Trunnion" style, not the round bar. Cequent has changed all these part numbers. I cant even find this online anywhere. Old inventory. These do have the radius on the chain end so you can use it on a dual cam sway control without having to add the old bolt on shoe that we used to have to add.
Old 02-29-2012, 06:26 PM   #4
FED 387
Mike---I need one of 2 things to work with my hitch either
the round trunnion bars
OR
the hitch head the part the ball fastens to for a bolt together adjustable height hitch bar for FLAT bar trunnions
Make sense???
The insurance company replaced my hitch with an adjustable head hitch but it is for a round bar trunnion not a flat bar trunnion-- I only have flat bar trunnions but the hitch head I have for a flat bar set up is the welded/fixed ball mount NOT ADJUSTABLE need to raise the ball up about 2-3 inches cannot do it with my setup--- can u help me??
Thanx Dick Ullrich FED387
Old 02-29-2012, 08:38 PM   #5
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Dick I've got a good used head for the flat bars and 1 good flat bar. PM me if you are interested.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 02-29-2012, 10:18 PM   #6
FED 387
mark sent u a pm--Dick
Old 03-01-2012, 09:05 AM   #7
Mike Gardner
headless, thanks.
Old 03-01-2012, 09:46 AM   #8
FED 387
thanks for your help
