Old 03-24-2012, 11:29 AM   #1
Doug Domm
Liked 84 Times in 21 Posts
Default Battery charger choice for Optima type battery?
What are the negatives to using a non AGM type charger on an Optima battery? What is a suitable charger for between round charging car battery and a seperate charger for trailer battery maintenance? The trailer charger will operate every time the generator is run. Both car and trailer batteries will likely be Optima type.
Doug Domm is offline   Reply With Quote
Old 03-24-2012, 11:50 AM   #2
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Default Re: Battery charger choice for Optima type battery?
I've used a Red Top Optima battery for years and never used a "special" battery charger.Never had a problem either.
Old 03-24-2012, 12:34 PM   #3
magnumv8
While it may not be common,I, DO NOT recommend using a regular battery charger on any type of AGM battery.....I was bench charging one of my Optimas and was gone for a few minutes and when I came back there was a flame coming out of the vent a good 6 to 8 inches high (it was set on low).....I am glad it was on the bench and not in the car, there would have been nothing left......
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 03-24-2012, 12:39 PM   #4
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Can. tire had a nascar (schumacher) m/prossesor charger on sale last week 40% off,for 70.00. Has agm, deep cycle, etc. good charger. Sometimes they will give last weeks sale price. gsa612
Old 03-24-2012, 12:43 PM   #5
Liked 1,874 Times in 422 Posts
CTEK is supposedly what Optima recommends.
Old 03-24-2012, 12:44 PM   #6
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Optima has their own charger coming out this Spring, here's a link to it -
http://www.optimabatteries.com/optima_products/charger/
Here's some charging information on the Optima/AGM batteries -
http://www.optimabatteries.com/produ...t/charging.php
Good Luck!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-24-2012, 01:13 PM   #7
442OLDS
442OLDS's Avatar
D L Rambo.....
Might be a good idea to get that charger checked out.
Old 03-24-2012, 01:29 PM   #8
magnumv8
Not an issue with the charger, the charger couldn't sense the charge condition of the battery and because of that didn't "back down" the charge rate....I install charging systems in emergency vehicles that are connected 24/7 and you need a system that can sense the charge and roll it back so as not to cook the battery but still left on the battery so it maintains it's full charge....
D L Rambo.....
Old 03-24-2012, 01:33 PM   #9
treessavoy
Liked 4 Times in 4 Posts
Good Luck!
Lew
Lew,
Thanks for the good info.
JimR
Jim Rountree
Old 03-24-2012, 02:28 PM   #10
Doug Domm
Yes Lew thank you for the info. If I'd had my thinking cap on I should have went to the Optima site in the first place! Having said that this has provided some technical dialogue. Bonus! Doug
